quickie 1.1 PJCCS typo?
bugeyes
Was wondering if the following are typos in the manual;
1.connect OA to B6...., wouldn't it be OB to B6 since OA is already connected to A2 on the A side of the circuit.
2.B6 is already connected to 6L...., if the circuit is symmetrical, the A side has OA going to A2 which is an unoccupied pin on the tube socket. Seems to reason OB should go to B2, is this correct ???
If I am reading the schematic right, seems the pins 2 and 6 are basically the same connection?
I went ahead and just used the schematic and it fired up just fine. I would suggest that maybe you would want to clarify the previous points ;D
