I replaced the 249K resistor incorrectly in R3(B) with a 2.56K resistor I fashioned together. Close enough I assume. Amp comes up and IB settles out at 290V and the amp plays and the second set of LEDs light up. So that appears to have been the problem. Not sure what happened. I checked all of the resistors before I put them in.
Here is the odd thing. I went back and checked the board we replaced and the resistor in that board was 2.49K ohms as it should be. So I replaced a bad board with some problem somewhere that was causing muffled sound and non-lighting LEDs. I put in a new board and didn't notice I had the wrong resistor which caused the same muffled sound and non-lighting LEDs even though the original board had the proper resistor. Go figure.
I suppose at this point I will just be thankful for the help and let it play.
