madbrayniak
I did a little searching and I didnt find anything like this so I thought I would do a little bit of math for some quick reference for you all to look at.
In the following example I did three quick mock ups of a possible Bottlehead setup.
All Bottlehead systems include the top of the line kits. Mainline, BeePre, and Eros Phono stage and a couple different amps for comparison.
System 1: Bottlehead system above w/ Paramount Monoblocks and Soft Start Kit-Total Price before tax and shipping: $4871
System 2: Bottlehead system above w/ First Watt F5(build price of $1000 *estimated*)-Total Price before tax and shipping: $3923
System 3: Bottlehead system above w/ Hypex nCore NC400 monoblocks (rounded price up to $1400)-Total Price before tax and shipping: $4323
The only thing missing from these systems is a DAC which I will add later once the final price is announced.
For comparison purposes I averaged these prices together which is $4373.34.
Going to Stereophile.com and looking at their recommended components list there are very few Integrated Amps that are in this price range in their "Class A" rating column. A couple that are in this price range are the Luxman L-505u at $4100, Leben CS300 $3395, Bel Canto C7R $2995, and Ayre AX-7e $3500.
From what I can see, doing a quick search, none of these have HT-Bypass and only the Leben is a tube based integrated.
So by going with Bottlehead not only do you have a fully seperate audio system where you can personally go in and optimize/mod the electronics for your purpose and choose an amp that best matches the impedance of your speakers but you have added flexibility for the same or lower price. The price of used Bottlehead gear can also be the same cost as it was for you to build it or possibly a bit more.
What do you lose with Bottlehead? Possible loss in resale(see above). McIntosh gear is known very well for holding it's value for resale later on which is a big selling point in my eyes. Another thing that some might consider a loss is the fact that you cant really take it to a local stereo shop and have it repaired under any type of warranty. There is also a bit less of an "Oh yea, I spent $XXXXXX on my sound system" ego boost. There is also the additional cost of tubes that will need replacing throughout the years that you wont have with Solid state gear. But keep in mind that solid state gear clips harder and in a less enjoyable way than tubes do. Enclosure is not extruded aluminum that can be dropped from a three story building.
Here is something to also consider with the Bottlehead+F5 system, the lowest priced Pass Labs integrated amp is still $7000 and you will have a high performance system with a Nelson Pass designed amp for a little more than HALF the price and you still need a phono stage.
