OK, I'm having a different issue that seems conceptually related to my first question, so I thought I would post it here.
I just got stereo powered subs (Omega DeepHemp 8s) to go with my Omega CAMs (which are terrific with my Bottlehead gear). I'm running speaker wire from the posts of the CAMs into the DeepHemps. Here is the issue - with my main system off, and with the sub "on" but not receiving signal (it has one of those signal detection circuits, so there is a little red light that goes on under these circumstances, which turns to green when it sees a signal from the amp) I hear a hum in my CAMs (not in the sub). It is loud enough that you can hear it if you are sitting in the chair that is next to the speaker. If I actually turn off the sub this goes away, and it is not a ground loop (because it is not resolved by an isolation transformer), and it is not RF noise because if I switch to shielded speaker wire it is still present. Here is the kicker - it depends on my main amps also being hooked up to the speakers - if I unhook the speaker wires coming from my Paramounts (which, again, are off when this happens), the hum goes away as well.
Any thoughts as to what might be going on here? Anything worth trying (short of switching to RCA inputs from my pre, which is impractical given my room configuration)? I could of course turn off the subs whenever I'm not using the system, but that is a bit of a pain, and I wonder whether this noise is adding to my tube noise when the main system is actually on. And of course, I'm not hurting the Paramounts or their tubes as a consequence of any of this, am I?....
