pstrisik
Hi All,
I'll start a thread for my build progress and questions along the way. Just getting started. Stain just applied to the base.
First question: What is the assembled weight of the Moreplay including tubes? Rather than the rubber feet, I will be adding recessed squares of wood at each corner in order to rest the pre on IsoAcoustics OREA vibration insulators. The weight determines which OREAs all of which are different diameters and height. I'm guess the smallest, graphite, whose sweet spot is between 9 and 15 lbs for four of them.
I should ask to be safe, is there an 1 1/2 inches or so clearance from the bottom to any components at each corner?
Thanks.......Pete
Thanks.......Pete
