Progress is slow - I'm back at work so other things must take up time.
I thought I'd knock up a couple of Camille CCS just incase things go wrong with the Tucker ParaglowMk2 and I can revert to Paraglowmk1. I've already found two very simple and fundamental probs with how the previous owner was wiring the amps up - almost too simple to see! That however is dealt with.
Back to the CCS...
Consider the Paraglow mk1's CCS (and also the Active SEXamp CCS in 'Valve' many moons ago.) I was soldering away merrily using 'verobard' and I thought, 'just a minute ...'
I have a few copies of another US magazine in which a contributor is using a Camille CCS and he reverses the pin outs of the two transistors (a 2N2097 equivalent (PNP) and MJE 350) such that the 350's emitter is down to the valve's anode and the 2907's collector is joined to the HT via a 100 Ohms current setting resistor. Surely this is a mistake! If Paraglow's CCS works then the other cannot!?
Back to the CCS...
