(This has probably been asked before)If parafeed SE amps shield the OT primaries from PS noise, is there any benefit to be had by upgrading the PS caps to films?
The potential benefit is smaller than with series-feed circuits, but still greater than zero.
Film caps are much larger than electrolytics, which makes it tempting to reduce the capacitance. But the capacitance still plays a role, so I discourage changing the value - unless you recognize it's an experiment that might fail. :^)
This is a little off topic, but if you can reduce hum by altering, say, the input tube connection, then that noise would not be due to the PS, right (or wrong)?
