MarimbaMan
I finally pulled the Parabees out of the closet and built them after 6 years. All resistance checks out fine, except
for T1 and T2 on both sides.
Manual spec on these terminals is 155-165 ohms
My readings:
T1 T2
Left 910k ohms 970k ohms
Right 810k ohms 910k ohms
I double checked all connections, the RRSFs are connected to 1S and 1F on the transformer. The 10 ohm resistors are
not resting on the paper cover on the transformer. The UF4007s are oriented correctly, as are the filter caps. I
double checked the bleeder resistor, it is attached properly. It appears I made the same mistake on each amp, since
the readings are so close. any ideas? thanks in advance
My readings:
T1 T2
