Padding the Pot
So the goldpoint pre-attenuation circuit definitely looks like the way to go if you want to pad your input signal by more than a few decibels (to say nothing of preserving input impedance).  It has been about a decade since I took any class relating to E&M, so I enlisted my physicist father to help me with some napkin math while we put back a couple of Newcastles on the 4th.
To recap from page 1, I'm using a 100k TKD pot in my crack, and was planning on simply adding a pair of 75k ohm resisters in series with the inputs to pad the volume.  However, after calculating it out, it turns out that 75k ohm resisters in series with a 100k pot will actually only reduce the input signal by about 5 db.  By contrast, adding in the 75k ohm resisters and also a second set of resisters (R2 as shown in  http://www.goldpt.com/mods.html), of approximately ~33k ohms, bridging the input and ground terminals of the pot, will reduce the input signal by nearly 12 db, while also preserving the impedance.
This should be about perfect in my setup since I am often lowering the volume in Foobar by ~10 db if I have my pot in the vicinity of 9:00.
Thus supporting my theory that the cocktail napkin was the most significant invention of the 20th century. Moon landings and cloud computing probably wouldn't exist without it.
Has anyone here tried running a resistor in parallel with a pot output to ground? I've seen it done before and it pulls the attenuation curve into a nicer shape (compared to a linear pot that is), though it does mess with your input impedance.
Check the link in the second post, reply #1.  One of the drawings shows just that.  I haven't tried it but maybe VoltSecond might chime in?
Hmm nope, didn't see a picture that matched what I was talking about...
Actually I found a link: http://sound.westhost.com/project01.htm
