tdogzthmn said:Would you be able to explain what is going on in the charts you posted? I dont have an engineering background but I am interested in your findings.
Dr. Toobz said:Nice graphs, but I'm confused. The graph labeled as "6AS7" shows lower -3dB values for a given impedance, with the 5998 graph being opposite. For example, JH16 Pro (18 ohms) is listed as needing a coupling cap of 47uF to get a -3dB point of 25Hz with the 6AS7, yet the same value is listed as yielding a higher (36Hz) point with the lower resistance 5998. Since the 5998 has a lower Rp than the 6AS7, shouldn't the -3dB be lower for any given impedance/cap combo? Maybe the graph labels were reversed?
jrebman said:Steve,
Somewhat OT, but do you think you'll be coming to the RMAF CanJam in mid-October?
-- Jim
Paul Joppa said:The chart is for a voltage source/cap/load but the Crack has a 120 ohm output impedance. The cutoff in the bass goes with the total of 120 ohms plus the headphone impedance, so the 160-ohm line shows about what you can get with any low-impedance phone. You do not need a huge capacitor unless you do something (different tube, feedback, etc) to lower the output impedance.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
