Im finishing up my Seduction build and my question is related to it but I think it's better asked here.
Im going to use Obbligato 1.0uF caps on the Seduction outputs in place of the included .47uF Orange Drops. The Obbligatos are close to the same physical size but they are heavier (I think they have a shrink wrapped, metal case).
Because they arent too large, I'm sure that I can install them just like the pictures in the manual, one leg soldered directly to the terminal strip tab and the other directly to the solder "cup" of the output RCA jacks.
So, the caps would be supported by the connection/soldering of their two leads. However, I have seen a couple Seduction build photos now where upgrade output caps (Obbligatos in one case, I think) that, size wise, would fit fine if mounted as per the manual pictures were instead attached (with blue-tack or a tie-strap mount etc.) to the underside of the chassis and then the leads bent accordingly to reach the terminal strip and the RCA jack.
So my question is ... is there any advantage/disadvantage to just soldering the caps to the terminal strip and RCA jack as in the manual photos and letting them "hang" as opposed to securing/supporting them to the underside of the chassis? Conversely, is there any advantage/disadvantage to securing them to the chassis? The only thing that I can think of is that securing them to the chassis, the leads would have to be left a bit longer, but other than that, does anyone see any advantage or disadvantage either way?
