There should only be two in there.Larpy said:I'll order 4 and change them all.
One of the resistors from grid to ground (pins 2/7) on that 12AU7 isn't doing its job.Larpy said:KregA on the D socket board measures 24v (A side output is 294v).
Yes, that is definitely causing one of your issues.Larpy said:I checked for continuity among the legs of all 6 transistors on the C socket board (above the 6922/7308) and there's no continuity except for the 2N2222 on the left channel side of the board. That means this one needs to be replaced, correct?
This sounds very familiarLarpy said:Apparently, all the troubleshooting I've been doing over the past week was just tracking down the problems I created myself in trying to diagnose the distortion sound.
Yes, I suspect there's something that's not in the DC current flow path that's poorly connected and causing AC issues. If you have a phone with a headphone jack on it, you can play music at one volume setting above mute into your Eros and poke around while it's playing to see if you can change the behavior of the issue.Larpy said:Paul, you suggested earlier that it's a problem with the preamp's AC, since I heard the distortion even while measuring the correct DC voltages. The DC is happy but somewhere the AC is not. A dodgy connection to ground perhaps? Would anything else cause these symptoms?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
