Quiet_Storm
I recently changed out the power supply boards on my 2A3 v1.1 Paramounts. When I rechecked all the voltages, I noticed that my OB pad voltage had increased significantly. Instead of being 151 volts like when I originally built them, they read ~180 volts. Everything else looked fine, and I went ahead and adjusted the potentiometer to set the values back to 153 volts. Is it normal for the values to change over time?
Also, I solved a multi-year issue related to some white noise on my left channel during startup! Apparently, one of the diodes had a cold solder joint, so the startup voltage on B6 was high. Once the regulator kicked in it would drop and the white noise went away. I'm not sure how I missed that before, but I'm so glad that's finally resolved.
