No resistance at OB and B3 (Speedballed Crack) [resolved]
Colonl_Charisma
Hi everyone! I switched the output caps to Dayton Audio 100uf/250V film caps today, and when I went to do my resistance checks I did not receive a value at OB or B3. However, OA and B6 had a recorded value of 116 M ohms. The other pins on the octal socket had resistance values except for B3. Ground value on the large board was 0 ohms. Also, resistance checks on the small board checked out.
I did do some desoldering with solder wick in order to open the holes of T6, T7, T9, and T10.
Crack with Speedball was working without issue before.
I'll check those real quick. I was hesitant to turn the amp on because I did not pass the resistance checks. I'll post voltages soon.
The manual states that the resistances of OA and OB should be very high, in the hundreds of K ohms (or it could be over the limit of my meter). I looked in my multimeter manual, and it does say that it could take several seconds for very high resistance readings. When I wait several seconds I still do not get a reading.
I am trying to figure out what the display for over limit readings are.
Thanks, PB! All is well. Looks to have been a false alarm with my multimeter not registering a value because it was over the limit. Amp is working fine and sounding great.
