This would be a good time to try and measure the DC voltage of a 9V battery with your meter.
Paul Birkeland said:This would be a good time to try and measure the DC voltage of a 9V battery with your meter.
Paul Birkeland said:If you were on that setting and the amp was plugged in and turned on and you still got all those zeroes, then your fuse is probably blown.
Thanks. I'm pretty sure it was 0.19, but I'll check again.grufti said:It looks like you are measuring 190 VDC in your picture. I can't tell from the picture, if there is a decimal point somewhere, because you focused on the probes and not the meter.
Yes, the stain was just from painting the other side. Assuming you mean 1 and 2 as per the attached diagram, I got 239V AC.Paul Birkeland said:What is the stain on the chassis between the PT and the octal? It may be totally unrelated to your issue, but it's worth asking.
With your meter set to AC volts, what AC voltage do you get between terminals 1 and 2 on the power transformer?
So Paul do you mean like between 3 & 4, 5 & 6 etc? or what?Paul Birkeland said:How about the other pairs of terminals on the power transformer?
Paul Birkeland said:What DC voltage do you get between terminals 20 and 21?
Paul Birkeland said:How about between 14 and 15?
Paul Birkeland said:OK, despite it looking OK, it seems very, very likely that the 270 ohm resistor that runs across the power transformer is blown open. It's either that, or one end of that resistor is not soldered, or the black wire that runs next to it is not well connected.
With that resistor open, that first 220uF power supply cap will stay charged up. You can use a screw driver with a well insulated handle to short its terminals to remove its charge, or check out a YouTube video on discharging a capacitor with a resistor.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
