This was an absolute gas. Loved it. Absolutely thrilled with the sound. Built it to sweeten my DIY Decware Zenmaster 15 inch open baffle. A few suggestions from an admitted novice
1) Not clear which is the latest version of the manual.
2) A checklist for each step as done with the resistance and voltage checks.
3) Crowding problem at rear lug of balance pot could be solved with a 4 port wago connector ?
4) Raw B+ voltage test. After 5 minutes voltage still at 70v. Should one follow voltage rather than time interval?
5) cat 5 wire microscopic. After experimenting a bit, found best way to strip ends was with gentle pressure with side cutter. Any other suggestions?
6) Show clearly where to find the fuse and holder.
I think I noted a very few inaccuracies in the manual which otherwise was fabulous with its hi resolution photos.
1) 4 pole 3 position rotary switch on page 20. ( left front corner?)
