Hi,
New to the forum and to Bottlehead. Just received the 1.1 kit and completed this weekend. I'm not getting proper readings and there is no sound. I did disregard one instruction. On page 20, the fourth paragraph reads "Attach and solder one end to pin B6" and I connected to "B2" since that corresponded to the photo and the connection for side A. Also, I added a second set of RCA outputs by connecting the ground lugs together and the center pins of side A together and the center pins of side B together. Readings follow:
A1, B1 are open line
A3 - 13 K-ohm, B3 - 12.4 K-ohm
A7, B7 are open line
4 - 1.07 K-ohm, 9 - 1.07 K-ohm
1 - 30V, 5 - 0V
2 - 38V, 6 - 30V
4 - 2.1V, 9 - 2.2V
5 - 0V, 10 - 0V
Rotary B - 0V
Rotary C - 3.2V
I did go over the wiring diagram again and things look right. What direction should I go in?
Thanks for any input.
Stephen
1 - 30V, 5 - 0V
2 - 38V, 6 - 30V
4 - 2.1V, 9 - 2.2V
5 - 0V, 10 - 0V
Rotary B - 0V
Rotary C - 3.2V
Stephen
