D
Guest
My parafeed amorphous core versions of the Lundahl 1679 OTs just arrived. They along with some 70H Lundahl plate chokes are intended for a rebuild of my SII-45 in the hopes of coming closer to the performance of the Kaiju, but with the EML 45B sound signature (the working theory being is that a good part of why the Kaiju sounds noticeably better than my SII's is the the better Kaiju iron).
The primaries of the 1679 can be configured for 2K6, 4K5 and 9K7 ohms. My eventual plans are to experiment with some higher plate-k voltages and different grid biases with the EML 45Bs using the 4K5 and 9K7 options. Jac at EML provides some example operating points to try out and I'll start with them first.[[Edit 2 - put first edit in wrong spot] Edit 1: and of course that will mean new power supplies with new PT and I'm guessing the need for a new shunt reg too - I've got some of that lined up, but not all, so it may be a while before I actually take a crack at SII-45B rebuild]
BUT ... these new toys have arrived and I want to try them out NOW, "just to see".
@PB or @PJ: just to try them, can I drop them in configured for 2K6 in place of the Kaiju 3K OT, and for 4K5 in place of the SII 4K OT? I figure the primary impedances are close to enough to stock to permit this, but I just want to make sure I'm not courting destruction of my beloved amps.
[Edit 3: and I realize that changing the primary impedance of the OT and/or the choke will affect the ideal parafeed cap value - but that's easy enough to figure out using PJ's 2L/R-sqr cap sizing formula. My concern is whether changing the primary impedance of the the OT will cause some kind of destructive mismatch between the output tube operating point and other parts of the amp - for example, the C4S]
MTIA, Derek
MTIA, Derek
