New Crack build, high voltage on T5 and T9
Greetings! First time build here. Everything has gone fine so far in terms of testing required in the manual, but I can't resolve a curious problem.
About 90 seconds after powering on, the LED attached to A3 will start to blink, then increase in brightness while voltage at T5 and T9 rise to about 140V and stay there. All other measurements are within spec until the LED blinks and T5 and T9 spike.
I've done all the obvious/routinely suggested trouble shooting, so I'm at a dead end. Can anyone help me out?
I have a three minute video of what happens which I'll try to attach or can send to those interested.
I would definitely be interested in seeing the build photos.  You may need to reduce them in size slightly if they aren't posting.
I would suggest resoldering all of the connections in the amp.  You can leave the ones alone where the LEDs are, as those look pretty solid.  Everything else needs more heat and more solder.
On the UF4007 diode bridge, that one that you have going up and over the black wire may cause some problems down the road and I would recommend going back to the manual and reviewing the installation instructions for that part.  It should not go over the black wire and the way it is installed allows for the possibility that the leads of it and the diode next to it can touch and short out the high voltage power supply.
I basically re-soldered the entire amp, and moved the diode, yet the problem still persists. Could it be a tube?
Short of dismantling it and rebuilding it, what are some options?
Updated pics enclosed.
Can you wrap the wires on the octal socket?  A loose connection on the octal socket could cause issues like that up at terminal 5.  This is very unlikely to be a bad tube.
Wrap the wire around the tube socket contacts rather than just letting it pass through.  This makes a solid mechanical connection before soldering.
Re-soldered the resistor twice now. No luck.
Re-soldered and crimped as best i can all terminals on the octal. No change.
T5 and T9 still around 140V.
I'm starting to be concerned my 'repairs' are making matters worse. T3 has a LOT of solder on it.
