This feels odd. The amp worked. All the LEDs were on, the volts and resistance was good. I listened to it through my Mac streaming tidal masters with my HD6xx headphones. Life was good. Then I took it down stairs and plugged it into the bifrost and it didn't work. I tried lots of scenarios down there, changing out the cords, plugging into different outlets, using a PC, plugging up my iphone with--and without--the phone plugged up via the camera adapter. Eventually I brought the amp back up here and discovered the LED's don't light up. I went back to the instructions and followed them, reflowing joints and testing voltages. I went to the forum and read threads on what could be wrong. I even replaced the LED's. Finally I come to you because I'm stuck.
I've reflowed the center leg of both MJE-350's. I've reflowed the joints for B7/B8 and A4/A5/A9. The Bifrost works with the iphone. I'm listening to it now through my Stereomour.
On the outer side of the LED attached to A3, the voltage reads 179. On the leg soldered to the center tap, it reads 172. The other LED reads the same.
Attached are photos of the LED's not working and both sides of the 12AU7 lit up.
AGW
