Hello,
I have my extended Foreplay for more than a year now.
Recently I changed the set of resistors on my Foreplay - the ones going from central switch to terminals 20, 26, 27, 29, 30, 36. I needed to decrease loudness and I installed 1/2 watt 470K-Ohm resistors (are these specs OK?), I bought in local RadioShack. When later I connected Foreplay and turned on music, I noticed my right channel gone. I checked wiring and found that the wire to RO1 central pin was broken. I re-soldered it, but right channel did not come back.
I made resistance and voltage check - results are below.
I personally think that the problem may be in some internal failure of the central switch - when I was switch it between the inputs - it does not into position right away. And as you see below resistance check on terminals 20, 26, 27 doesn't look right - I have infinity resistance reading for all switch positions. My guess - I need to replace central switch.
I also measured resistance across each new resistor individually - they are fine.
I would appreciate your feedback guys, may be somebody had this problem before.
RESISTANCE CHECK
Terminal Nominal Actual
Power Trans 1 infinity infinity
Power Trans 2 infinity infinity
Power Trans 3
Power Trans 4 * 10K to 100K 30,200
Power Trans 5 * 10K to 100K 30,200
Power Trans 6 infinity 1.37 Mohm and climbing
Power Trans 7 infinity 1.37 Mohm and climbing
Power Trans 8
Power Trans 9 infinity 1.37 Mohm and climbing
Power Trans 10 infinity 1.37 Mohm and climbing
LO1 470,000 471,600
LO2 470,000 472,100
RO1 470,000 472,100
RO2 470,000 472,600
LI1 33-48K / infinity 465800 / infinity
LI2 33-48K / infinity 465600 / infinity
LI3 33-48K / infinity 466.8K / infinity
H1 30,000 29,700
H2
H3
H4
Terminal strips
1 * 1.37 Mohm and climbing
2 * 0.6
4 * 0.6
5 0 0.6
6 * 1.37 Mohm and climbing
7 * 14 Mohm and dropping
9 0 9 Mohm and dropping
10 * 6 Mohm and dropping
11 470,000 471,200
12 83,000 60,000
15 infinity infinity
16 0 0.5
17 15,000 15,010
19 0 0
20 33K / infinity infinity/infinity/infinity
21 83,000 60,000
22 30,000 29,700
24 0 0.6
25 * infinity
26 33K / infinity infinity/infinity/infinity
27 33K / infinity infinity/infinity/infinity
28 0 0.4
29 33K / infinity 466K / infinity/466K
30 33K / infinity infinity/465K/infinity
31 infinity 40Mohm and climbing
32 150,000 150,600
35 470,000 472,000
36 33K / infinity infinity/infinity/466K
37 15,000 15,000
39 0 0
40 0 0
VOLTAGE CHECK
H1 26.5 27.03
H2 32.8 33.43
H3 -
H4 -
Terminal strips
1 - 94.00
2 - 0.00
3 -
4 0.0 0.00
5 0.0 0.00
6 - 95.20
7 230.0 226.80
8 -
9 225.0 221.50
10 220.0 216.00
11 0.0 0.00
12 150.0 151.00
13 -
14 -
15 75.0 74.70
16 0.0 0.00
17 0.0 0.00
18 -
19 0.0 0.00
20 0.0 0.00
21 150.0 151.00
22 26.5 27.03
23 -
24 0.0 0.00
25 -
26 0.0 0.00
27 0.0 0.00
28 -
29 0.0 0.00
30 0.0 0.00
31 75.0 73.00
32 150.0 150.40
33 -
34 -
35 0.0 0.00
36 0.0 0.00
37 0.0 0.00
38 -
39 0.0 0.00
40 0.0 0.00
RESISTANCE CHECK
Power Trans 3
Power Trans 8
LO1 470,000 471,600
LO2 470,000 472,100
RO1 470,000 472,100
RO2 470,000 472,600
H1 30,000 29,700
H2
H3
H4
Terminal strips
2 * 0.6
4 * 0.6
5 0 0.6
11 470,000 471,200
12 83,000 60,000
16 0 0.5
17 15,000 15,010
19 0 0
21 83,000 60,000
22 30,000 29,700
24 0 0.6
25 * infinity
28 0 0.4
32 150,000 150,600
35 470,000 472,000
37 15,000 15,000
39 0 0
40 0 0
VOLTAGE CHECK
H1 26.5 27.03
H2 32.8 33.43
H3 -
H4 -
Terminal strips
1 - 94.00
2 - 0.00
3 -
4 0.0 0.00
5 0.0 0.00
6 - 95.20
7 230.0 226.80
8 -
9 225.0 221.50
10 220.0 216.00
11 0.0 0.00
12 150.0 151.00
13 -
14 -
15 75.0 74.70
16 0.0 0.00
17 0.0 0.00
18 -
19 0.0 0.00
20 0.0 0.00
21 150.0 151.00
22 26.5 27.03
23 -
24 0.0 0.00
25 -
26 0.0 0.00
27 0.0 0.00
28 -
29 0.0 0.00
30 0.0 0.00
31 75.0 73.00
32 150.0 150.40
33 -
34 -
35 0.0 0.00
36 0.0 0.00
37 0.0 0.00
38 -
39 0.0 0.00
40 0.0 0.00
