We have been having nasty weather here in the Twin Cities. After one of the power-outages, I tried to fire up the preebee, and there was nothing :'( . I did an autopsy and found sooty residue near the power inlet. Taking that apart it looks like a short opened up in the power wireing, from the neutral lead to the sheild. I hoped that that ment that the problem ended there, prior to any sensitive parts. I made a new wiring harness and installed it. Everything is working perfectly.
My lesson learned was never leave homebuilt gear plugged in to a unswitched supply. It will be on my power-conditioner from now on with the others. It wasnt, because I was still testing things, getting my LED power switch wired up ect.
Another interesting problem I ran into was, a shorted rca jack. It wasnt a dead short, more like a 89k ohm short. Imagine the fun figureing that out (which to me is the fun of building the kits) a paralled resistance with the balance and volume pot, that was colse to the resistance of the pots themselfs. I thought the balance pot was bad then the volume , then both. After disconnecting everything back to the selector switch, and retesting was fine, I disconected the one rca jack that had to be the problem and it was. Fortunatly those jacks just come out of the recesses and I had another.
