Thanks for the FAQ, but I will do it with a better camera. Give me a few days.
Now to get into detail.
1) My earlier room had diffusers in front and abs on the rear. I wanted to try out a different layout. Helps in learning more and facing the new challenges that come with it. I have tried to keep a balance between the hard and soft walls, so no opposite sides have the same surface ( to a large extent)
There is a loft over the left speaker that measures around 4 x 6 ft. This is stuffed to make a bass trap. On the rear wall there is a loft which has my earlier bass trap ( 5ft x 18"). placed in there. A somewhat mid bass trap in the cavity of my listening sofa, which also is well packed with foam for seating.
2)Behind the left speaker, you may see something like a box. That is the power regulator for my air conditioner, which is a Diaken. Runs at about 28db, so you don't hear it. The power supply for the air conditioner is separate from the one that supplies the system.
There is a constant voltage transformer which supplies the power for the system. This ensures that the voltage is true and no junk gets in.
3)On the second shelf, you will see a wooden box placed sideways. It is plate amp for the sub. It drives the subwoofer that is placed behind the rack. This is the deathbox ( 10" down firing,adjustable cabinet). I did think about having 2 subs, and I do have a cabinet made, but for now I don't what to do too many things. Maybe a second sub later for fun. The sub sits on three brass footers which are placed on a maple wood slab, which is again placed on three brass footers.
4) The rack is maple wood with iso blocks and brass footers, which I got done here. The quickie sits on vibrapods and is placed backwards, for easy access to changing battery's and have shorter cable runs. The sex amp has a 9mm aluminum base plate(ventilated) , which sits on 3 brass footers.
5) The binding post on the SEX and speakers, as well as the bananas from the amp to sub are rhodium plated. Four of the six RCA's are rhodium plated. At present I have put in a ZBox which has a 12at7 mullard, which runs the mullards on the quickie, which runs the GE's on the SEX
. The sub cable is supra. The speaker cables are 8awg, 133 strand, silver plated copper. All power cords and tubes are cryo treated. I have a whole load of IC's (DIY) from Allen Wright's design to some belden as well. Power cord design are braided, twisted and shielded. The IEC are wattgate and some rhodium plated ones.
6) The SEX has the oimp vcaps and the quickie now has the obbligato and the pots are TKD.
And finally, I still think there is a lot to do
shreekant, a hard working audiophile!!
Oh! I forgot, in the third pic on the right corner is a glass.....it was blended scotch ( dewars, I love that stuff) with soda ( highball)!!!
