kscwuzhere
After starting with the Hd650's with the stock crack, I have done an immense amount of modding since and finally feel that I've found my ideal set up so I thought I'd share. I have since upgraded to the HD800's and only run the Bendix 6080wb slotted cross column graphite plates with either the RCA 5687 (for more rock oriented music) or the Amperex 7119 PQ (for jazz and less in-your-face music). The mods on my crack are:
-Speedball Constant Current Source Upgrade
-Dayton 100uF 250V Polypropylene Film Output Capacitor Upgrade
-PEC Volume Potentiometer Replacement
-Obligato 2.2uF 600V Polypropylene Film Power Supply Capacitor Bypass
-Russian Teflon K72P6 .056uF 500V Output Capacitor Bypass
-E80CC/12BH7A/5687 Variable Pinout & Resistance Mod
-Choke Inducer Upgrade on Output Supply (Oblong resistor replaced)
-Dayton 90uF 250V Polypropylene Film Output Supply Capacitor Upgrade
-Russian Teflon K75-10 4.7uF 250V Output Capacitor Bypass
To me, the significant mods besides the speedball were upgrading the output caps, replacing the pot, and retrofitting for the 5687 (made the biggest improvement). If you're running the hd800's I highly recommend my path of upgrade! Happy modding bottlehead!
