My Bottlehead Tandem - Quickie & Crack
wullymc
Hi everyone,
Finally going to put up photos.  Hopefully this works out.
1st build was the Crack a little more than 1 year ago.  I have just completed the Quickie and have constructed a base for it.  This is my first woodworking experiment.  Instead of spending the $40 on the base or the $99 base from Blumstein I spent probably close to $400 on tools!  Hopefully my woodworking skills will get better.
The Quickie has the PJCSS and I use it more as a switching device between my phono preamp and my dac.  The Crack is stock.    Next upgrades would be Output Caps on the Quickie and Speedball for the Crack.
I will be contructing a 13 1/4 X 11 1/4 base for the Crack.  I intend to use the extra space for large output caps and using the same stain to match the Quickie.
Question:  When installing the Speedball in the Crack would it be wise to desolder the output caps and attach fly leads so that upgrading the caps later will be easier?
Thanks for looking!....and thanks to everyone for helping along the way with the builds and my noobie questions!  :D
