denti alligator
Active member
A search for those who’ve upgraded the attenuator to the MourQuiet in their Stereomour II yielded very little. Could those of you who have installed this upgrade comment on the differences? Thanks!
But are you using the balance control because the channel balance of the stock pot isn't that great? Or for some other reason?denti alligator said:I think my main concern is the balance, which I definitely use, meaning the knob is nowhere near the center to get a properly balanced sound.
Not sure why the balance is appears to be off. I remember asking in another thread if the reason I need to use it so much is a sign of something else being wrong and was told no.Paul Birkeland said:But are you using the balance control because the channel balance of the stock pot isn't that great? Or for some other reason?
OK, I’ll try this and report back. Thanks.Paul Birkeland said:You can play a 60Hz tone into the inputs of your amp, then measure the AC voltages at the speaker posts (you can leave the speakers hooked up) at a normal listening level to see if the outputs are playing at the same level or if you're correcting for some other imbalance that isn't electrical.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
