Mirror Finish Paramount
Gerry E. said:
Hi Demsy:
Can you get 10 more pairs made?  This has "group buy" potential.  I'm only half joking.  Thanks.
Gerry
I can do that, Gerry, with pleasure. But the shipping cost would then be very high!
I built my paramounts with 304 stainless #8 mirror finish sheets as well a while back.  Was able to get the top plates fab'd via the interwebs through stainlesssupply.com
Entered the dimensions and aperture/ hole locations on their online form. They subsequently sent a dimensioned drawing to approve, then received the plates a couple days later in the mail.  Price was surprisingly affordable.
Easy peasy...
B
Easy peasy...
B
Well, there you go, guys, B makes it even easier! Don't forget to ask for the scribing/engraving service.
Thank you Demsy and B!
B - Would you be able to send me a copy of the dimensioned drawing and/or an order number from Stainless Supply?  I would like to order the same top plates and there's no reason to reinvent the wheel.  Thanks.
Gerry
Gerry
see attached drawing...please verify against your top plates for accuracy (i.e. don't necessarily trust my figures).  Also suggest you take actual measurements for your tube sockets and large parts as I had to do some filing with mine to account for part variation...easy when working with AL...more time consuming when working with 14G stainless steel.  Likewise, the slightly thicker sheet stock means that you may be right on the margin for screw length in some cases.
All this said, the process on Stainless supply's website isn't terrible.
I simply traced the top plate onto a piece of paper, then measured the original AL top plate with a set of calipers, marking off my traced drawing as I went to avoid missing any critical dimensions.  I used this to input figures into their web form.
NOTE: At the time, I thought I would save some $ by having them laser-cut the larger apertures and then drill the smaller holes myself on a drill press.  That is what is reflected on the attached drawing.  In hindsight, I would have them do everything and save the incremental effort.
good luck.
bryan
Bryan, out of curiousity, how much did you pay for the cut s/s plate? Just to get an idea how the operating cost differs from here.
Thanks Bryan. It's almost the same, I paid $75 but cut exactly as the original piece. Maybe the only difference is in the material thickness, I have mine cut in 2mm plate. Oh, and I had to have the drawing ready in their software for the cutting machine.
bjorgens said:
Gerry
good luck.
bryan
Thanks Bryan!  For both the drawing and additional info and suggestions.  Apparently I'm not the only one interested, it has already been downloaded over 25 times!
Gerry
