jbarnhardt
Hi all. I just completed my Mainline build and it was a very smooth process - no hiccups at all. My resistance and voltage tests all went well (one caveat noted below) but when I got to the final biasing step I have run into an issue. Biasing against terminal 20 works fine - it started around 147VDC and I quickly adjusted it to 145VDC. However, biasing off terminal 30, my initial reading is 3.64V! I can adjust this voltage up or down by a minor amount by adjusting the trim pot but it's clearly not in the right ballpark to begin with. I've swapped the 6C45 tubes but get the same behavior (terminal 30 is still the problematic side) and have confirmed that all 4 LEDs on both C4S boards are lit.
Any thoughts on where I might look for issues? My voltage readings are very close to what the assembly instructions specify. The one caveat referenced above is that in the resistance tests, I get 220ohm readings at terminals 19 and 22. These are tagged with an asterisk in the assembly instructions so I expected fluctuating readings or higher resistance, but since they were non-zero I assumed they were okay.
Thanks very much for any assistance you can offer.
-John
Seattle, WA
-John
Seattle, WA
