MOAR_CORES
Hello everyone,
I have been listening to the crack for a couple of weeks now, and right as I was about to install the speedball upgrade, my crack starting giving me issues.
The problem is that once every half hour or so, there is a large pop in the right channel, followed by dead silence.
The first time it happened, it was a progressive static sound that got really loud. Now its just a pop when it happens.
It is hard to troubleshoot this as the right channel comes back on within a minute, and gives me no time to troubleshoot.
However, what information I do have is that A6 on the 9 pin socket measures 150V, and the LED on A8 is off when the right channel is out. Then, the LED turns back on in under a minute and my crack works fine.
There is no visible damage on the LED. The LED does seem soldered rather close to the center pin of the socket (Maybe I should resolder it so the LED is further away from the center pin?)
All other terminals that I checked seemed to be fine while I was doing the voltage checks really quick.
One more thing, I remember accidentally shorting something while doing voltage checks once on the 9 pin socket when I first built the crack. A small spark appeared. I am unsure what I shorted, but the crack worked fine and passed all checks afterwards.
Thanks for the help
Thanks for the help
