OK, your meter is simply reading mV. I think your rectifiers are OK based on your measurements. Rectifiers in a bridge circuit will always read below OL in either direction, because the meter is in effect also reading the "backwards" rectifier that is connected to the rectifier you are measuring. If they blow they can create pretty close to a dead short so you would probably see a measurement much lower on the bad rectifier than on the good ones.
Actually it has sounded like a short is the problem from the beginning, but what is shorted is still the mystery. If one of the pins of the four pin socket is touching the chassis, that's a serious shorting problem that could certainly take out a fuse. If that is something that needs to be addressed I would make it the next priority.
