Left channel RCA jack not passing resistance check
Shackney1127
Finished building the Crack. Did resistance checks. Only thing that doesn't pass is the left rca jack. I get no resistance. My multimeter actually beeps sometimes. To my knowledge, this indicates a short. Any tips or advice?
The most common issue is a solder bridge between the outer shell and the center pin of the jack.
That looks like the case. Tried removing as much as I could with solder wick, but no dice. Guess I'll just order a replacement and try again.
