Full disclosure - this is my first amp build, so I have no doubt this is my mistake somewhere. I have doubled checked all the directions, and I will go back through and triple check them as well. However, the amp passed all resistance checks and voltage checks during/following the build. Worked great at first for a few minutes, then I started getting popping in the right channel. Found one loose solder, fixed it, that didn't solve the problem. I discovered that the LED closest to the middle of the amp (attached to A8) lights up ten seconds after amp is turned on, but consistently goes off again after the amp is on for three minutes. I re-soldered this LED and tried to make sure there is some play in it. It was pretty tight before, but now has some room to move around. Didn't solve the problem. Just to clarify, the other LED (attached to A3) stays lit without issue. Here are the voltages I'm getting once the LED turns off as well as the initial voltage checks following the build.
Terminal (initial voltage check) (with LED out)
1. 83.6 151
2. 178 168
3. 0 0
4. 178 167
5. 83 80
6. 0 0
7. 107 151
8. 0 0
9. 109 103
10. 0 100
Drew H.
1. 83.6 151
2. 178 168
3. 0 0
4. 178 167
5. 83 80
6. 0 0
7. 107 151
8. 0 0
9. 109 103
10. 0 100
Drew H.
