Hello, I am putting together the Kaiju kit using the manual Kaiju_Manual_01-17-22-9jah5y.pdf.
I am on page 38. Instructions say,
“Strip the black and red wires ¼" (7mm). Using the end with the drain wire, attach and solder the red wire to D1. Attach and solder the black wire to D9. Route the cable to leave the socket towards the rear. Attach and solder the drain wire to the solder tab at the base of the standoff.”
I want to check that D1 and D9 do not need a 220Ω ¼W resistor, same as to the wiring for A1 and A9 (pg.37 of the manual).
Thank you,
Raymond
Thank you,
Raymond
