I intojazz New member Sep 27, 2011 #1 I have an Extended Foreplay III and am in the process of converting the output tubes to 6sn7's. I want to keep the 12au7 as the shunt regulator. The heater supply resistor is currently .62/5w . That resistor should be changed to .22/5w? Correct?
P Paul Joppa Moderator Sep 27, 2011 #2 My notes say 0.15 ohms for 1.5 amps (0.6+0.6+0.3) assuming your power line is close to 120 volts.
