Moderator
I spoke with the technical guy (Eddie) at Eurotubes today. So far as I understand it the only problem they have actually seen was with Paramounts in the direct coupled 2A3 version, and it sounds similar to the problems that led to the soft-start which is now standard on that amp. It seems that at least one of their customers does have the soft start board and still had the problem, so there are still some questions. Further testing will be done by Eurotubes and/or JJ on the "bad" tubes - that information will help us understand what happened more clearly. Both Bottlehead and Eurotubes are in contact and will keep each other up to date; we will post news when we have it.
So far, I believe there should be no unusual problems with Stereomours, and no such problems with soft-start Paramounts either unless the 20-minute rest after shutdown is ignored. Eurotubes will update their warranty policy as more is learned, so if you want to use those tubes check for the current status before ordering.
