Natural Sound
Active member
First off, I'm running relatively stock Paramour II's. I may entertain the possibility of shunt regulation in the future. For now they are not.
I'm dying to get the stock Speco output transformers out of the amps. I'm having a hard time deciding on which parts to buy though. I've been doing a lot of reading in the archive. The more I read the more confused I become. I've fallen into, "analysis paralysis." I could use some help to knock me off the fence.
Here is what I gather so far. The BH-5 outputs (Similar to TFA-2004 Jr.) and BH-6 plate chokes are less suitable from a technical standpoint for 45 use. The operating points cannot be optimized for maximum power and the damping factor is poor. But some have compromised because this is a "great sounding transformer." After all its all about the sound, right?
The other option would be the EXO-45/46 Output transformer and a set of BH-2 plate chokes or BCP-15 (50 henries at 40mA) With this combo the operating points can be better optimized and the damping factor is better. However low end bass may be less using this output transformer.
With that in mind I have a few questions.
1) Which do you think is better and why?
2) What is the definition of, "damping factor" and how does it effect the sound?
3) Will a parafeed cap of 10uf be OK for either option?
4) If I have a choice of output impedance, which would be better for a pair of orca's and 2 subs, 8 or 16 ohm?
Thanks, Tom
Thanks, Tom
