I've just finished an Eros 2 build. All went well; the resistances and voltages checked out just fine (pp 74-76).
When I put into my system, the right channel was "out." I did some cable troubleshooting and then I exchanged the left and right EF86s.
What I found was that moving the RHS EF86 around in its socket (a slight pushing/pulling on the tube) caused the side to work/not work. I took the preamp back to the bench and tried reflowing the pins and adding a bit of solder.
That didn't help. Working through the top of the socket I tried to "bend" the socket pins closer to each other with a scriber. That didn't help.
At this point I can cause the right channel and/or the left channel to stop working by slight movement of the tube. It's as if the tube pins push the socket cup pins down and there isn't a good (proper?) connection. The socket top and bottom ceramic(?) seem to have a lot of slop. There is a definite tube socket sweet-spot (back/forth and up/down movement of the tube) to get the channel to work.
I'm wondering what else I could try.
I can replace both tube sockets from what I have. But I don't have any size 90.9 ohm resistors and I don't have any zero ohm ones; would these be a replacementparts@ set of parts? Is there a cost associated with four resistors and four jumpers?
I would prefer to resolve this at this point-in-time as opposed to just leaving it with the two tubes sort-of working and then having them wink out due to vibration or heating/cooling of the tubes/sockets.
Thank you.
Thank you.
