I recently ordered a Stereomour and a Crack. I am familiar with electronics assembly. I am a little knowledgeable about electronics but only solid state before this effort.
I'm intending on using my Stereomour's three inputs for various sources -- on day one, probably a turntable with preamp, a CD/SACD player, and a USB DAC with fixed line level coming in. I'd also like an output running to the crack for whatever input is selected. I have found a few discussions, some related to the Foreplay, on how to do this, and read what I can, and it seems like a few others have at least talked about it, but no reported results. Has anyone done it?
What I'm looking for is the absolute best way to integrate these, not necessarily the simplest.
My initial thought was just to take the output from the Stereomour's input switch and run the signals and ground over to a new set of output RCAs and connect those to the crack's input, and then power up the Stereomour for speaker listening and the Crack for headphones. I understand that the 100K volume pots in each device would be in parallel and create a 50k resistor for the inputs, which I have seen posted here would be fine for 'most sources'.
* What sort of sources might have a problem with this?
* If I swapped out the volume pots on both devices for 200K versions putting the resistance of the inputs back at 100K while connected in parallel, would I eliminate any risk?
* If I did substitute 200K pots, and then I disconnected them and used the crack separately, would the increase from 100K to 200K across the volume pot potentially cause any issues?
I have also seen from the Foreplay threads that putting a 1K protection resistor between the two outputs is advised. What would be the upside/downside to doing this on the Stereomour (1K in line with the wire headed to out jacks from the input selector)? Is it necessary? Is there a better way to isolate these outputs? In some other circuits I have used a op-amp buffer but i don't believe I have DC under the hood here (haven't seen the manuals yet) and sonics were not critical in those applications, would like to keep this closer to stock and not route the signal through anything unnecessary.
Is there a better way to do this that I haven't considered?
Your opinions are appreciated.
