Installation of nylon stand off
mpent
I am having a hell of a time trying to install the nylon standoff to the chassis for the C4S upgrade....can someone help?  Thank you.
Michael
Hello Michael,
Are you installing the C4S kit on the most recent SEX kit (2.1 - with Bottlehead PC-3 and OT-2 transformers?).
Did you remove the nut on the 5-lug terminal strip holding the two 220uF caps?  Is the standoff not fitting properly?
Is there a part that's in the way, or is it not threading on?
If it's not threading on, is it too large, or too small?
OK, as indicated in the instructions, this screw replaces the screw that holds on the central terminal strip.
Does the screw that you removed from the finished stock SEX amp not fit the standoff?
Ok, I am a bit confused.  The instructions do not indicate to remove screw from chassis securing terminal strip.  It says to remove the nut from said screw, then install standoff. But yes, looks like the issue is that the screw currently securing the terminal strip is too large to fit the standoff.
Ok, I think I am seeing my mistake now.  I de-nutted the screw from the wrong terminal.  I misinterpreted the instructions and disoriented the chassis configuration.  The instructions call for de-nutting the screw in front of the power transformer (terminals 1-5).  I de-nutted the screw from terminal exactly behind terminals 1-5 mistakenly...terminals 21-25?  I should be focusing on the "terminal strip" 1-5...instead I was misinterpreting and thinking I was focusing on terminal that was closest to the power transformer terminals 1-5.
So...I am focusing on terminals 1-5, that which contains (2) 220uf capacitors as indicated in your previous post....sorry for the confusion.  From observation, that screw looks like it will properly thread.  Thanks for the second set of eyes....
Michael
Yeah....I am definitely known to make such mistakes.  It's in there now and everything checks out proper.  Definitely tightened up the low frequencies. Loving it.
Michael
