( ) Begin with the right channel autoformer, nearest the power entry module. Trim the red wire of the autoformer to fit, to reach the top hole of terminal 5. Strip back 1/4" , and attach but do not solder the upper hole of terminal 5.
( ) Route the blue wire under terminals 5, 10 and 15, and trim and strip back 1/4" to reach terminal 20. Attach and solder the blue wire to the lower hole of terminal 20.
( ) Twist the black and orange wires from the autoformer secondary together. Trim to fit, strip and attach the orange wire to the upper hole of terminal 5. Solder the upper hole of terminal 5.
( ) Trim to fit and attach the black wire from the secondary to the top hole of terminal 10. Do not solder terminal 10 yet.
( ) Now wire the left channel autoformer, nearest the RCA jacks. Trim the red wire of the autoformer to fit, to reach the top hole of terminal 25. Strip back 1/4" , and attach but do not solder the upper hole of terminal 25.
( ) Route the blue wire under terminals 25, 30 and 35, and trim and strip back 1/4" to reach terminal 40. Attach and solder the blue wire to the lower hole of terminal 40.
( ) Twist the black and orange wires from the autoformer secondary together. Trim to fit, strip and attach the orange wire to the upper hole of terminal 25. Solder the upper hole of terminal 25.
( ) Trim to fit and attach the black wire from the secondary to the top hole of terminal 30. Do not solder terminal 30 yet.
