Incorrect voltages after installing Speedball [resolved]
I've resoldered pretty much everything and the buzzing is unchanged.
I really can't tell what the problem is. Also, thought I'd mention I have the resistor mod for the pot installed but other than that everything is completely stock.
I removed the Speedball upgrade and it seems that the amp is working, so it appears that the problem is not the power supply. What are the most common mistakes to look for on the PCBs? Also, is it possible to install each of the PCBs one by one in order to see where the problem is?
You can put just the small boards in, then run the amp with the 3K resistors in place (and the 22.1K resistors removed).
Yeah, I'm getting the noise in both channels. Even after resoldering I'm still getting it; not sure what's wrong.
Can you try connecting a source and listening to the amp?  With unshorted inputs, you may end up getting some noise.
When plugged into my source I can hear music over the buzzing. The music is not distorted at all and the buzzing now appears to be softer in the left channel in comparison to the right. Right now I have the 3K resistors in place of the large PCB and the two small PCBs in the amp.
After a day of troubleshooting the problem is still exactly the same.
It's definitely not the power supply or anything that's in the stock Crack, as that works fine. It seems that the buzzing is being caused by the small PCBs but after resoldering every joint on them the problem remains. What should I do next?
Edit: With the large PCB and the 22.1K resistors between the red wires meant for the small PCBs, the amp functions perfectly, so I'm assuming that the connections of the red wires to the terminal strip are fine. All four resistors on the small PCBs measure correctly, even when measured from their solder joints on the boards. All four LEDs glow brightly and are in the correct orientation. At this point I'm assuming the problem is either one of the MJE350 transistors or a 2N2907. What is the most accurate way to test them?
If you believe the transistors are the problem, then they should be replaced.  It's possible that one set of transistors was damaged from the R1 swap, but not both sets.
The transistors on the small board with the swapped resistor would be the ones most likely to be damaged, correct?
Is it okay to test the circuit with one of the small PCBs and one 22.1k resistor? That would definitely help with confirming the problem.
Both boards are causing the same buzzing sound. Do you think that there are blown transistors on each board or could something else be the cause of the problem?
Yes, I think you have an issue elsewhere.  I still believe that you have an iffy connection in your amplifier, and the Speedball constant current sources are simply more sensitive to the issue than the stock circuit.
There could also be an environmental problem close to the Crack (computer, wifi router, etc.) that could be causing some interference.  It might not hurt to try the amp in another room.
I tried a different location and interference doesn't seem to be the problem. I guess I'll go through and resolder everything again.
I've once again resoldered pretty much everything. Where should I go from here? I really don't want to just continuously resolder every joint; I feel like after all of this it is almost definitely a problem with one of the components. Could the transformer itself be causing the buzzing?
Easy to check, make the screws are all tight then add some weight on top of it. Or just push down on it with your hand, but use a piece of wood or something in between....it can be hot!
Doing that test didn't affect the buzzing so it appears that the transformer is fine. I'm really stumped about what's causing this buzzing.
