Paul Joppa said:
That's why it took three double-pole switches for each transformer.
Because I don't understand how the OT wiring works, the idea that an impedance switch for the SII requires only 3 On-On switches for each OT is completely baffling.
In my attempt to figure out an impedance switching mechanism for the SII, I have treated the OT as a black box and assumed that for each of the 4 impedance wiring schemes (2, 4, 8, 16 Ohms) only those connections indicated in the manual may be made. So far, the only on-paper solutions I have come up with are: (A) one 2-
polethrow, one 3-
polethrow, and two On-Offs; or (b) a four position quad deck rotary switch that simply combines the previous solution into one switch. Not very elegant. And neither of these include a switch for balanced/unbalanced!
I won't post more details because I don't want to be responsible for someone toasting their amp, or worse.
I'm sure others who understand the OT wiring, and/or are better at combinatorial puzzles, can figure out a more elegant way of doing things.
I'm going to keep working at it. And then test the solution by having resistors with different values stand in for each of the 6 relevant OT terminals - the idea being that I work out what the net voltage drops for the various connection chains should be, and then use my meter to see if that's what I get in different switch positions. Not yet sure whether this will actually work as a test of the solution.
cheers,
Derek
[edited to correct my mistaking "throws" for "poles"]
