D
Guest
A recent thread about using Y-splitters -- http://forum.bottlehead.com/index.php?topic=12941.msg103120;topicseen#new -- got me thinking about a related idea: an adaptor with built in resistor for using lower impedance headphones with the Crack. IIRC correctly, the Crack has an approx. 120 ohm output impedance and so is best suited for HPs with a input impedance of twice that or more.
But, judging by the frequency with which people ask whether they can use Brand X or Y HPs with, say, 25 to 200 ohms input impedance, it seems that a lot of Crack owners also own lower impedance HPs and would, if it could be made to work, like to listen to them with the Crack.
So, as a fun and fairly cheap experiment/project, why not build an adaptor that increases the impedance that the Crack "sees"? As best as I can tell, all that would be required is a resistor (preferably non-inductive) in series with the HP. So, for example, a 250 ohm resistor in series with 50 ohm HPs would bring the "seen" impedance up to 300 ohms, and thereby hopefully prevent wonky bass response. One could even experiment with setting the "seen" impedance even higher -- e.g., 600+ ohms. The limiter here would be the current requirements of the HP. A low impedance HP that wants a lot of current may not work (i.e., low sensitivity HPs). But I would think that this would work with low impedance, relatively high sensitivty HPs.
I won't be trying this anytime soon as I have a different HP system (see signature line) and lots of other projects on the go -- but others might want to give it a try, unless PB, PJ or Doc say it's a bad idea for some reason that I can't think of. All you'd need is a 1/4" headphone plug, the resistor, and a 1/4 jack, some bits of wire and maybe some heat shrink.
cheers, Derek
cheers, Derek
