Grainger49
My brother in law has a refurbished Wurlitzer model 1015. Cool looking but takes odd 78 one sided records.
The amp was kind of refurbished and just crapped out the other day. There is a wedding coming up and he wants it to work for afterward.
Here is the set up. It came stock with an octal full wave tube rectifier. I am guessing that was expensive so it was replaced with a 5Z4 full wave, four pin. I get the incoming B+ on the AC side, the plates but downstream I get about 1/2 a volt from the cathodes to ground. There is a 20uF/450V cap between the 5Z3 cathode and ground.
I tried a newly bought tube, still the same voltage.
I tried to snug up the socket pins, still the same voltage.
There is377V correction 480V AC coming into the rectifier, between the plates, and next to nothing coming out.
Any suggestions would be happily accepted.
There is
