hum balance potentiometer
kompakt
Hello!
I bought a stereomour in 45 config, and i like to build the the stereomour now for 2a3. the previous owner hast remove the hum balance poti.. In pdf manual is this a 10ohm potentiometer. Now i wanna buy witch and dont now if  a 10ohm ( 1W ) is ok  for this job. How much watt most have this potentiometer?
Best Regards
Seyed
The power rating should be on the parts list at the beginning of the manual.
By the way, the hum balance pot should still be needed for 45 operation.  I have no idea why it was removed.
Hello!
On the pdf manual is only 2-10 ohm wirewound potentiometers.. and n how much Watt..
I have found this 10ohm wirewound  Pots on ebay:
http://www.ebay.de/itm/2-Stuck-DDR-Potentiometer-Poti-Drehwiderstand-10-Ohm-10R-1Watt-Einstellregler-/281078995470?pt=Bauteile&hash=item41719d1a0e
Do you think this are ok?
Regards
Seyed
