Hum and no audio
Cleaned out the RCA's and resoldered the caps. Tested it still nothing out of one channel. I have to go pick my boys up from school. I will be able to make a run at this again tomorrow.
OK, find a device (phone/tablet) with a headphone jack and download either a signal generator app or a 60Hz tone.  With an 1/8" TRS to RCA cable, you should be able to measure the AC voltage coming out of the RCA jacks and turn the device all the way down, then up one step on the volume control.  Let us know what AC voltage this is.
Plug the RCA cables into your Reduction with the Reduction off an measure the AC voltage across each RCA jack and let us know what it is.
The Fluke 115 has a mV range and it looks like it will default to AC mV, which is what you want. I would expect your phone to put out maybe 300mV at max volume and somewhere between 5 and 10mV one step above mute.
Sorry for the delay I had life get in the way and had to get a TRS to RCA sourced. I am a big unclear as to where to and how to measure on the RCA I want to make sure I get you a good reading.
Plug the TRS to RCA into your device, download a signal generator app and play a 60Hz tone.  Put your black meter probe on the shell of one RCA plug and the red probe on the center of one RCA plug, set your meter to AC millivolts, then adjust the volume all the way down on your device, then up one click.  Let us know what that AC voltage is that you see.
Black input 49mv
Red input 52mv
Black output 55mv
Red output 81mv
It fluctuates a lot and is tough get get a good reading on it.
You're not quite following what I'm asking you to do.
1.  Put the Reduction in another room, close the door, leave it alone for now.
2.  Plug the 1/8" TRS to RCA cable into your phone/tablet/whatever.
3.  Download a signal generator app.
4.  Play a 60Hz tone though it.
5.  Turn the volume all the way down, then up one click.
6.  Now measure the AC voltage across each RCA plug at the end of your TRS cable.
The minimum AC voltage that can come from most devices will be a lot lower than 50mV.  Be aware that your meter has a different setting for AC millivolts that will give you more stable readings.
Perfect, now grab your Reduction and plug those RCA cables into the inputs.  You don't need to apply power to the Reduction, just the RCA cables.
Now read the AC voltage across the input jacks.
OK, that tells you that the input jacks aren't clogged with debris.
Power the Reduction up and play that tone into the inputs.  You can just anchor your black meter probe to the grounding screw if that's easy for you, then measure the AC voltage at:
6
10
19
23
Sorry, i was all mess up on the last one heres a retry
6-13mv takes a bit to get there starts at like 6 and slowly climbs
10-230mv
19-0 and one of the led's blinks when i test it
23-140mv
27 -12mv takes a bit to get there starts at like 6 and slowly climbs
After probing more, it only makes a led blink off if I have the Fluke in mv if its in regular ac volts I don't get the Lightning bolt icon and the led doesn't go off, I am wondering if that's the meter causing the leds to go out.
No, you have a loose connection making the LED flash.  There isn't anything about what the meter is up to that will cause that.
Ok if that's the case, when I measure with the meter in ac mv heres where leds blink
2- led to 3
7- both leds
13-led to 3
14 led to 3
15 both
18 both
19 led to 9
20 led to 9
26 both
29 9
31 9
Sorry this is taking so much of you time and such a pain, I really appreciate the help.
