Help with Speedball
Greetings again and thanks in advance.  I have been using my Crack HA for the past two years and finally decided to add the Speedball.  It has worked perfectly until now.  After I installed the Speedball the numbers didn't match the voltages so I rechecked that I placed all the wires correctly and resoldered them to be sure.  Both tubes light up (the 6030 is well lit, the 12AU7 barely glows but gets warm). I replaced the 1 Amp fuse.  Now I don't have any correct numbers!
Terminal lug# on the PT-3 and #12 for the negative lead on the DVM
1-O VDC
2-0 VDC
3-no lug
4-0
5-0
6-86 VDC
7-86
8-no lug
9-86
10-86
11-0
12-0
13-174
14-0
15-194
16-0
17-0
18-86
19-86
20-0
21-214
22-0
I had a spare 12AU7 tube so I replaced that tube.  Same thing.
Any ideas?
I have to say that I'm a little disappointed that there has been no response to my dilemma regarding the addition of Speedball to my original Crack. I have always received prompt helpful answers to my questions. I'm tempted to remove my Speedball addition and return to my basic Crack.
Photos here.  THanks.
Lo and behold.  I rewired all of the speedball and many of the previous Crack soldered joints and now it works as designed.  Sorry to trouble you.  TG
