Hey guys. I just finished putting together the Speedball upgrade for my Crack. I had a working Crack amp before the upgrade but I believe there was an issue with the initial wiring. During testing after the upgrade, when I would push on the black wire leading from the left input jack to the lower lug of the potentiometer the sound would pop and cut out and the LEDs would blink off.
I've tried reflowing the solder joint at the potentiometer but it hasn't made a difference. In fact, I seem to be making things worse, since now the LEDs won't come on at all. Also, since the solder joint is in a difficult to reach spot surrounded by wires I keep burning insulation on the surrounding wires trying to reflow the joint.
My initial Crack build passed all resistance and voltage checks as did the Speedball upgrade. But now everything is screwed up and I don't know how to test the original resistances since I've removed the 4 resistors as part of the Crack upgrade. Can someone clue me in on what the resistances should be after the Speedball upgrade? Anything else I should be looking at? I can post my resistances/voltages if you want. Thanks!
