Hi all
I just finished to build the eros. Now the resistance checks on the pins 1 to 15 looks like I have about 15% more resistance constantly on all the pins that should have resistance. Example: on a 74k I will have 84kohm.
I went on and did the V check and all the points on the pc boards are spot on a part 1. This one is OA on the red side ( with the plate flipped that would be the left pc board. This OA reads 209 instead than 170. I tried the Eros in my system and as I was expecting the black channel works and the red channel I get very low signal (music) and lots of crackle. Is this related to the reading on OA pc board of the red channel? I can attach some pics if needed.
I already re soldered pin 9 and the red cable that goes to the OA board with the problem but nothing changed.
Please any help would be greatly appreciated!
Best
AB
Best
AB
