unowndanger
Hi,
So I bought the crack 3 years ago, and set everything up. Pretty frequently I'd get some hissing or white noise and audio drops with the crack, and I chalked it up to poor soldering on my part. I went inside a couple times to reflow things and check resistances, and everything seemed to work.
Last night, I was only getting audio out of the left earcup. I first tested the cables the headphones directly into my desktop to make sure it wasn't the headphones, then tested the RCA cables with another audio source (and a different pair of cables) and I determined it wasn't that. The tubes were glowing, at least the larger of the 2 were. I didn't check the smaller one, but it was previously working.
I would plug everything back in to test, but I disconnected everything to run a resistance check and the below are my results. I'm hesitant to plug everything back in to run a voltage check until my resistances are all correct.
Terminal Manual My Reading
1 * 0 Ohms
2 * 0 Ohms
3 0 Ohms 0 Ohms
4 * 0 Ohms
5 * 0 Ohms
6 2.4K ohms 0 Ohms
7 2.9K ohms 2.95k ohms
8 0 Ohms 0 Ohms
9 2.9K ohms 2.9K Ohms
10 2.4K Ohms 0 Ohms
12 0 Ohms 0 Ohms
13 Will climb slowly 0 Ohms
toward 270K Ohms
14 0 Ohms 0 Ohms
20 0 Ohms 0 Ohms
22 0 Ohms 0 Ohms
B3 2.9k Ohms 2.95K Ohms
B6 2.9k Ohms 2.94K Ohms
I'm unsure how to proceed with trouble shooting this. I misplaced the PDF of the manual and basically scoured the forum to final a relevant resistance check table for me to add my findings to. I am attaching photos below of the soldering job as well as many photos of the entire build as close up as possible. Any and all help is appreciated.
1 * 0 Ohms
2 * 0 Ohms
3 0 Ohms 0 Ohms
4 * 0 Ohms
5 * 0 Ohms
6 2.4K ohms 0 Ohms
8 0 Ohms 0 Ohms
10 2.4K Ohms 0 Ohms
12 0 Ohms 0 Ohms
toward 270K Ohms
14 0 Ohms 0 Ohms
20 0 Ohms 0 Ohms
22 0 Ohms 0 Ohms
